[GRASS-user] DB Driver
achim ak7 at jupiter.uni-freiburg.de
Thu Mar 12 10:52:56 EDT 2009
DB-Driver's eating my nerves.
Im running grass6.4 on 64bit opensuse11.1
Has anybody had and maybe fixed a problem concerning database
driver-errors? I can hardly go on working with errors like this:
Removing vector <AOI at achim>
DBMI-SQLite driver error:
Unable to open database: unable to open database file
Unable to open database </home/achim/grass/globe2/achim/sqlite/> by
driver <sqlite>
Unable open database </home/achim/grass/globe2/achim/sqlite/> by driver
<sqlite>
Unable to find table <AOI> linked to vector map <AOI>
couldn't be removed
<AOI> nothing removed
Thanks,
achim
achim schrieb:
> Hi all,
> its confusing me:
> Making a new table seems to work, but I got an error and looking at the
> table does not work as well. I get the message:
> Displaying column types/names for database connection of layer 1:
> driver <sqlite>
> The same is with DB driver. When I make a new table in the DB I get:
> Using user specified table name: AOI_nontant
> Creating new DB connection based on default mapset settings...
> Creating table with columns (cat integer)
> The table <AOI_nontant> is now part of vector map <AOI_nontant at achim>
> and may be deleted or overwritten by GRASS modules
> driver <sqlite>
> Unable to open database <$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/> by
> driver <sqlite>
> Reading features...
> driver <sqlite>
> Current attribute table links:
> driver <sqlite>
> Vector map <AOI_nontant at achim> is connected by:
> layer <1> table <AOI_nontant> in database
> </home/achim/grass/globe2/achim/sqlite/> through driver <sqlite> with
> key <cat>
> Whats wrong?
> thanks,
> achim
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
