[GRASS-user] working with vectors
Moritz Lennert
mlennert at club.worldonline.be
Fri May 15 11:53:11 EDT 2009
On 15/05/09 12:23, achim wrote:
> Hello folks,
> I wonder, how you deal with vector-data. I am really not happy with it,
> even with help from qgis. Do I have to go deep into PostGis (which does
> not support topology, as far as I know) to make some more or less
> advanced working steps like selecting areas, which intersect with
> another,
v.select. In grass 6.x it only provides the option "overlap", but in
grass7, you get the full GEOS set, i.e.: equals, disjoint, intersects,
touches, crosses, within, contains, overlaps, relates.
> combine line vector layers and break on intersections
v.patch + v.clean
>, measure
> length of lines even in an latlong projection...
v.to.db, although I'm not 100% sure how that deals with lat-long. Only
comment in the man page:
"When calculating perimeters in Latitude-Longitude locations, the
geodesic distance between the vertices is used."
I would suppose that this is the same for line length...
> Any hints for dealing with vector data in fossgis are welcome.
You have tons of options. GRASS has a very advanced vector engine and
you should be able to do most of what you need, once you get used to it.
Start by reading this:
http://grass.itc.it/grass64/manuals/html64_user/vectorintro.html
Moritz
