[GRASS-user] Strategy For DBMS Use
Pablo Carreira
pablotcarreira at hotmail.com
Wed Nov 18 19:48:38 EST 2009
I have very nice results with sqlite+GRASS.
First, use an sqlite administrator software to make things easier.
> 1) My initial impression is that I need a separate database for each layer
> (i.e., one for highways, a separate one for streams & rivers, etc.). Is this
> correct?
One database for each LOCATION, one table for each vector.
One way of working is that You can put rivers, highways, power lines, etc. in the same "layer" and put a column in the table that describe what kind of object it is. You can play with CAT number too, like rivers is cat number x and highways is cat number y.
Then for example:
Displaying the vector you say: x=blue y=black.
In the sql you say: SELECT * FROM table WHERE description="river"
Try no to think as the obsolete shapefile style gis.
> 2) Do I manually create the databases and specify table schema within each
> location's dbf/ directory?
Just create the table and connect the LOCATION to it. "db.connect".
Any new vector or command tha creates a vector, creates also a new table in the sql database.
> 3) If I want to write SELECT statments that JOIN tables in different
> layers, then I need to open one database and attach the others. Is this done
> within GRASS?
I have never tried joining tables in different databases.
> I'm sure that I'll have more questions as I learn how to use SQLite with
> vector attributes. The soils data in particular, has a couple of dozen
> tables associated with it.
I am a agronomist engineer an I have made soil maps and soil use maps with grass, just ask if you have more questions.
Pablo Torres Carreira
Brazil.
_________________________________________________________________
Agora a pressa é amiga da perfeição. Chegou o Windows 7. Conheça!
http://www.microsoft.com/brasil/windows7/default.html?WT.mc_id=1539
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20091118/1a87911f/attachment-0001.html
