[GRASS-user] wxGui query raster/vector
    Martin Landa
    landa.martin at gmail.com
    Fri Oct  2 15:43:21 EDT 2009
2009/10/2 Nikos Alexandris <nikos.alexandris at felis.uni-freiburg.de>:
>> probably related to the spatial index changes in GRASS 7.0(?). You
>> need to rebuild topology using v.build or v.build.all (this will
>> create spatial index file).
> is this the same as my question wrt to v.select? I get the same message
> which demands to build topology (post in the list entitled: v.select
> error (latest grass_trunk)).
> Will this affect working in grass6x? Or is it an external spatial-index
> which won't affect current workflows?
the vector maps created/modified using GRASS 6.x requires rebuilding
topology in GRASS 7. GRASS 6.x remains unaffected.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
