[GRASS-user] wxGui query raster/vector
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Fri Oct 2 15:49:22 EDT 2009
On Fri, 2009-10-02 at 21:43 +0200, Martin Landa wrote:
> Hi,
> 2009/10/2 Nikos Alexandris <nikos.alexandris at felis.uni-freiburg.de>:
> >> probably related to the spatial index changes in GRASS 7.0(?). You
> >> need to rebuild topology using v.build or v.build.all (this will
> >> create spatial index file).
> > is this the same as my question wrt to v.select? I get the same message
> > which demands to build topology (post in the list entitled: v.select
> > error (latest grass_trunk)).
> > Will this affect working in grass6x? Or is it an external spatial-index
> > which won't affect current workflows?
> the vector maps created/modified using GRASS 6.x requires rebuilding
> topology in GRASS 7. GRASS 6.x remains unaffected.
Thank you, Nikos
