[GRASS-user] Re: Using v.surf.rst
    madi
    diregola at gmail.com
    Fri Apr  9 02:27:39 EDT 2010
Hi Eric,
I think the problem is that you have to set you region with g.region
http://grass.itc.it/gdp/html_grass64/g.region.html
Cheers,
Margherita
> Message: 5
> Date: Thu, 8 Apr 2010 18:31:09 -0700
> From: "Eric" <temp at johannsen.us>
> Subject: [GRASS-user] Using v.surf.rst
> To: <grass-user at lists.osgeo.org>
> Message-ID: <00a501cad784$54f5f2e0$fee1d8a0$@us>
> Content-Type: text/plain; charset="us-ascii"
> I'm very new to GRASS and an experienced programmer.
> My goal is to import isolines (elevation lines) as well as elevation points
> from another mapping program into GRASS and then interpolate a raster based
> on the vector data and then export as a DEM file.
> To that end I have reviewed
> http://grass.osgeo.org/grass64/manuals/html64_user/v.in.ascii.html
> http://grass.osgeo.org/grass64/manuals/html64_user/v.surf.rst.html
> I think I understand the principals but am getting stuck on several details.
> As a simple test I attempted to create an ASCII file with X Y Z coordinates:
> myFile.txt
> 593493|4914730|123
> 591950|4923000|222
> 589860|4922000|232
> 590400|4922820|143
> 593549|4925500|442
> 600375|4925235|342
>  import with
> v.in.ascii -z input=myFile.txt output=secondTry z=3
> I get v.in.ascii complete (no error messages)
> and then
> run v.surf.rst input=secondTry at PERMANENT elev=secondTryRaster
> This yields the error
> some points outside of region -- will ignore...
> there are points outside specified 2D/3D region--ignored 6 points
> ERROR2: zero points in the given region!
> ERROR: Input failed
> Keeping in mind I'm completely new to GRASS (and don't understand a lot of
> the jargon), can you explain what I'm doing wrong?
> Also, can you recommend a tutorial that covers this type of conversion
> oriented toward beginners?
> Thanks!
> Eric
> After importing the data points, I do not see anything at all visually in
> GRASS GIS Map Display.
Eng. Margherita Di Leo
Ph.D. Candidate
Methods and Technologies for Environmental Monitoring
Department of Environmental Engineering and Physics (DIFA)
University of Basilicata
Campus Macchia Romana
85100 - Potenza
Italy
Office: +39-0971205363
Fax: +39-0971205160
