[GRASS-user] Compare GRASS versions
Micha Silver micha at arava.co.il
Fri Apr 23 04:46:41 EDT 2010
Markus Neteler wrote:
> On Thu, Apr 22, 2010 at 10:38 AM, Jenny Turner
> <jennyturner1980 at gmail.com> wrote:
>> Greetings
>> I'm preparing a small GIS tool to High School students to do some image
>> processing, image vizualization etc and I'm thinking of using GRASS since is
>> free and pretty much do what I need. But I realized that 6.4, 6.5 and 7 have
>> different characteristics, functionalities.
> 6.4 and 6.5 are rather close, 7 is starting to deviate.
Also, don't ignore the option of QGIS. With the GRASS plugin you can do
quite a lot, and it's easier and quicker to get started and visualize
results.
The ready made QGIS installations usually include GRASS 6.4
>> What I need to know is if there
>> is any document that compares and assesses these 3 versions in order to
>> characterizes each one.
> To my knowledge there is none. The Wiki would be the right place to
> start it.
>> For instance GRASS6.5 is able to have dynamic
>> wxpython scripts (e.g. v.krige) that is an interesting funcionality.
> Yes - but for stability reasons (in case you need it in production), you
> may consider 6.4. If functionality is missing and available in later
> versions, it could be discussed to backport it for 6.4.1 if not too
> complicated. Otherwise, take the next higher version number.
> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
> This mail was received via Mail-SeCure System.
Micha Silver
Arava Development Co. +972-52-3665918
http://surfaces.co.il
