[GRASS-user] Compare GRASS versions
Jenny Turner
jennyturner1980 at gmail.com
Mon Apr 26 05:14:16 EDT 2010
Thanks Markus
So the main reason for still supporting GRASS 6.4 is its stability right?
For instance, do you plan to launch 6.5 as a end-product?
Thanks
Jenny
> 6.4 and 6.5 are rather close, 7 is starting to deviate.
> > What I need to know is if there
> > is any document that compares and assesses these 3 versions in order to
> > characterizes each one.
> To my knowledge there is none. The Wiki would be the right place to
> start it.
> > For instance GRASS6.5 is able to have dynamic
> > wxpython scripts (e.g. v.krige) that is an interesting funcionality.
> Yes - but for stability reasons (in case you need it in production), you
> may consider 6.4. If functionality is missing and available in later
> versions, it could be discussed to backport it for 6.4.1 if not too
> complicated. Otherwise, take the next higher version number.
> Markus
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100426/c3838074/attachment.html
