[GRASS-user] python module under wingrass7
Thu Dec 16 08:20:31 EST 2010
gianluca.massei wrote:
> now .py extension is registered correctly and my module ends with
> correct code but  The error  message is the same. In linux (ubuntu 10.4
> LTS) all works fine but in windows my module and all other python
> standard   modules (e.g. r.mask) return same error. If I set
> PYTHONPAT=C:\Python27 I have this message " [...] no module named
> grass.script"
PYTHONPATH should contain the path to GRASS' Python directory, i.e.
%GISBASE%\etc\python. It shouldn't contain any other entries.
PYTHONHOME should not be set.
PATH shouldn't need an entry for Python.
GRASS_PYTHON should contain the complete path to the Python
interpreter.
