[GRASS-user] r.watershed resolution issue
Hamish
hamish_b at yahoo.com
Fri Feb 5 01:59:24 EST 2010
Justin Cole wrote:
> I am using r.watershed module in GRASS 6.4
> running in QGIS 1.4 and every time I run it I get the result
> very quickly but it is very course. I have tried it in
> both windows and mac working and they give the same result.
> I cannot tell if I am doing something wrong but I need to
> figure out how to get the same result but to match the rest
> of the data so I can do other calculations on it. I am
> using LiDAR data of 5ft per pixel.
check that the computational region settings are set to match the 5ft/pixel.
(g.region) This isn't done automatically.
also check that the threshold setting is set to something appropriate.
Hamish
