[GRASS-user] I.class empty Xmonitor
Luisa Peña
luisapena1979 at gmail.com
Mon Feb 8 04:47:57 EST 2010
Hello Hamish
I'm running Ubuntu 9.10 and GRASSsvn6.4.0 updated with an early January
snapshot.
UbuntuGIS package? I don't have an UbuntuGIS package.. I installed the
packages that are listed in
http://grass.itc.it/grass64/source/REQUIREMENTS.html (more or less those).
>It only opens the monitor for you if you select it from the GUI menu.
It opens an empty/blank monitor but nothing else. no Interactive menu or
what so ever.
Is is required that UbuntuGIS package?
2010/2/8 Hamish <hamish_b at yahoo.com>
> Luisa wrote:
> > I do have installed. I'm running in Ubuntu
> > and with xterm version 243.
> hmmm. The ubuntu package asks for "x-terminal-emulator". Where does that
> symlink lead to? (there's a debian-specific patch in the package)
> what version of ubuntu is this again? UbuntuGIS package version?
> > By the way, I decided to run it not from
> > wxpython but from command line and I got this:
> > (Thu Feb 4 12:45:01 2010)
> > i.class map=lsat7_2002_20 at PERMANENT
> > group=lsat7_2002 at PERMANENT subgroup=lsa7_2002
> > outsig=out(Thu Feb 4 12:45:01 2010) Command
> > finished (0 sec)
> can you try from the actual terminal command line, not from the GUI
> Cmd> prompt?
> you will have to run "d.mon x0" first.
> > And nothing happened. Am i suppose to open a monitor
> > before or is it suppose to open by itself?
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100208/0a2dcc17/attachment-0001.html
