[GRASS-user] to separate a polygon
Vincent Bain
bain at toraval.fr
Tue Feb 9 10:37:22 EST 2010
AFAIU :
* your network was digitized as a single polygon, contouring
streets/roads and crossroads in one go ;
* you would like to turn it into a linear reference network.
Am I right ?
If no special splitting was initially performed on boundaries to
distinguish between connected street sections I fear you'll have to do
things manually...
Vincent
Le mardi 09 février 2010 à 16:03 +0100, Yvan Paillé a écrit :
> My road network was digitized into a polygon. Initially, I need to
> separate into two distinct parts by half. In a second time, I need to
> cut each polygon based on the streets and of belonging to adjacent
> parcels. As if I would define a sidewalk.
> Only the first step is already causing me problems.
> Thank you
> Yvan
> Vincent Bain a écrit :
> > Yvan,
> > could you please state your intention ? and clarify how your network is
> > represented : are roads delimited by polygon boundaries and crossroads
> > by nodes ? or was the network digitized as a polygon (I mean giving
> > roads thickness) ?
> > First, about data type conversion, you can have a look at v.type.
> > Yours,
> > Vincent.
> > Le mardi 09 février 2010 à 15:14 +0100, Yvan Paillé a écrit :
> >> Hello,
> >> I would like to separate a polygon that represents a road network into
> >> several polygons or polylines. I do not know what functions to use to
> >> display vertices and nodes.
> >> Thank you in advance for answers that guide me.
> >> Yvan
> >> _______________________________________________
> >> grass-user mailing list
> >> grass-user at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/grass-user
