[GRASS-user] r.profile grass64_rc5 - grass7
John Tate
john.tate at ntlworld.com
Thu Feb 18 14:18:53 EST 2010
Hey Francesco,
I'd be interested to hear what other people have to say about this.
I used d.what.rast as I had ground control points, from GPS, for the profiles
with which to validate the DEM. Add columns and update them with d.what.rast
and export (.csv), then I put that together with the distance info from the
GPS data.
Hope that helps. But probably not if your are drawing random profiles.
John
On Thursday 18 February 2010 15:42:31 Francesco Mirabella wrote:
> Hi all,
> I am trying to use the r.profile module on a DEM. I have tried on both
> grass64_rc5 and grass7 with wxpython gui.
> In 64_rc5 there still exist the "old" option which allowed the user to
> interactively select the end-points by mouse, but the function does not
> appear to work as I get:
> ------ r.profile -i input=DEM output=profile
> Using resolution [90.0161]
> No socket to connect to for monitor <cairo7>.
> ------ I can use it only with the oldtcltk
> In grass 7 the possibility to choose the end-points with mouse is not
> there any more
> can someone give hints??
> By the way, the display profiler in the monitor works good in 64_rc5 -
> not i grass7 (I guess it's the "old" d.profile") but I cannot see any
> way to export the data in ascii format (distance-elevation) to load them
> into a spreadsheet
> more hints??
> many thanks
> Francesco
