[GRASS-user] Raster surface from regularly spaced points
Luigi Ponti
lponti at infinito.it
Fri Feb 19 06:41:09 EST 2010
Thanks Markus!
On 19/02/2010 11:52, Markus Metz wrote:
> You can try the overhauled v.surf.bspline module. You would need to
> svn up to get the new version, available in grass64 and higher.
I was browsing the source code but did not see it
http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/vector
http://trac.osgeo.org/grass/browser/grass/trunk/vector
Am I looking at the wrong spot?
I will probably get it in the next grasswin standalone installer, but I
also need source code to update an heritage cygwin/grass version.
> run v.surf.bspline with the -e flag first to get estimated mean
> distance between points. If your points are not completely but almost
> regularly spaced, multiply the estimated distance by 1.5 and use that
> value for sin and sie.
This is great fine-tuning get me up and running -- thanks.
> BTW, method=bicubic gives much nicer results than method=bilinear.
I think it is slower, isn't it? Not sure how much slower, though.
> To conserve the range of the original data, use a low lambda_i value
> somewhere between 0.01 and 0.1.
> I would be really interested if it works for you!
I will let you know. Thanks again,
Luigi
> Markus M
> Luigi Ponti wrote:
>> Hello,
>> I have a grid of (almost) regularly spaced vector points from which I
>> would like to get a continuous raster surface. I say "almost"
>> regularly spaced, because the grid is almost square in that the
>> position of points derives from a netCDF grid with a different
>> projection than the current GRASS location. One cell of this
>> non-aligned grid covers several raster cells at the current region
>> resolution.
>> So far I have been using a v.surf.idw approach but I am not sure
>> whether that is appropriate. An exact interpolator would be best, but
>> at least I want conserve the range of the original data.
>> According the the GRASS book (p. 228), my options would be v.surf.idw
>> and v.surf.rst but the latter does not conserve data range, I think.
>> Another idea would be to use bilinear interpolation.
>> Any hints very welcome and thanks for your attention if you got so far,
>> Luigi
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
