[GRASS-user] Raster surface from regularly spaced points
Markus Metz
markus.metz.giswork at googlemail.com
Fri Feb 19 06:50:08 EST 2010
Luigi Ponti wrote:
> Markus Metz wrote:
>> You can try the overhauled v.surf.bspline module. You would need to
>> svn up to get the new version, available in grass64 and higher.
> I was browsing the source code but did not see it
> http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/vector
> http://trac.osgeo.org/grass/browser/grass/trunk/vector
> Am I looking at the wrong spot?
Nearly there ;-) It's part of the lidar tools in e.g.
branches/releasebranch_6_4/vector/lidar but a generic surface
interpolation tool. As such, it is in the GUI in Raster -> Interpolate
surfaces -> Bilinear and bicubic from vector points. You need to make
distclean for the whole source code when compiling the new version
(updated header).
>> BTW, method=bicubic gives much nicer results than method=bilinear.
> I think it is slower, isn't it? Not sure how much slower, though.
A bit, but IMHO it's worth it. Still faster than v.surf.rst.
>> Luigi Ponti wrote:
>>> Hello,
>>> I have a grid of (almost) regularly spaced vector points from which
>>> I would like to get a continuous raster surface. I say "almost"
>>> regularly spaced, because the grid is almost square in that the
>>> position of points derives from a netCDF grid with a different
>>> projection than the current GRASS location. One cell of this
>>> non-aligned grid covers several raster cells at the current region
>>> resolution.
>>> So far I have been using a v.surf.idw approach but I am not sure
>>> whether that is appropriate. An exact interpolator would be best,
>>> but at least I want conserve the range of the original data.
>>> According the the GRASS book (p. 228), my options would be
>>> v.surf.idw and v.surf.rst but the latter does not conserve data
>>> range, I think. Another idea would be to use bilinear interpolation.
>>> Any hints very welcome and thanks for your attention if you got so far,
>>> Luigi
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
