[GRASS-user] Searching Docs about 3D geological modelisation
Christian Kaiser
Christian.Kaiser at unil.ch
Fri Jan 8 09:38:10 EST 2010
It seems to me that this is a 3D interpolation problem with categorical variables.
Maybe the Bayesian Maximum Entropy approach could help. There are some interesting publications around also for geology and soil sciences, and they can deal with categorical data as well. Look for example here: http://www.enge.ucl.ac.be/staff/curr/Bogaert/biblioBME/BMEbibsubject.html#Soil%20Science
Or maybe you can have a look at SGeMS (http://sgems.sourceforge.net), a tool for 3D geostatistics.
None of them is available through GRASS, but the algorithms are freely available (I think open-source, but not verified).
I am not a geologist, so please forgive if it is not adequate...
Christian Kaiser
On 8 janv. 2010, at 11:04, Benjamin Ducke wrote:
> Rich Shepard wrote:
>>> material. There is no interpolation algorithm in GRASS currently which
>>> can
>>> handle that sort of data well.
>> So what is needed is a political algorithm. :-)
> That's actually right: given the presence of n different
> layer types in the vicinity of an empty voxel, the algorithm
> would need to decide by some sort of "majority vote"
> which type to assign to that voxel.
>> Kidding aside, I suspect that a fuzzy interpolation algorithm would solve
>> the problem.
> How? You could make the interpolated value depend on a
> fuzzy set member function, I suppose, but the situation
> here is actually so well defined that I think a probabilistic
> approach would be preferable. Since each voxel can only
> store one value, a second output map could store the
> classification probability. That may be very useful
> for visualization (you could show voxels with little
> probability hazier).
> Ben
>> Rich
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> Benjamin Ducke
> Geospatial Consultant
> Oxford Archaeology Digital
> Janus House
> Osney Mead
> OX2 0ES
> Oxford, U.K.
> Tel: +44 (0)1865 263 800 (switchboard)
> Tel: +44 (0)1865 980 758 (direct)
> Fax :+44 (0)1865 793 496
> benjamin.ducke at oadigital.net
> http://oadigital.net
> Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
