[GRASS-user] GLOBCOVER import and manage
    Gilbert Ferrara
    gilbertferrara1974 at gmail.com
    Fri Jan 15 10:28:40 EST 2010
Greetings All
First of all let me warn you that I'm new at GRASS :)
Ok, I need to use ESA GLOBCOVER product for a certain area of the map
(Belgium) and I'm not sure I'm doing this right.
1- I have defined location folder
2- Defined "Read Projection and datum terms from a georreferenced file"
where I chose  my GLOBCOVER file
3- Then I inserted a top/bottom Lat and left/right Lon. I imagine a square
around Belgium
4- Then I import my European GLobcover image (bigger then my defined
region).
And it seems to be working :)
Now, If I have an image (e.g. IKONOS) with a ddiferent coordinates system,
when I import, GDAL automatically converts to my coordinate system? And how
about image resolution? because, IKONOS has a bigger resolution. Will it be
changed to be according to Region set and with Globcover product?
Thanks
Gilbert
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100115/938cb6fe/attachment.html
