[GRASS-user] Issues in v.distance and v.overlay
Richard Chirgwin
rchirgwin at ozemail.com.au
Sat Jan 30 20:40:25 EST 2010
Hi all,
In running some largish vector calculations that involved calculating
population, using areas overlaid with Australian Census Collection
districts (which have up to 12,000 areas), I've noticed a couple of
issues with the above modules.
v.overlay - Is leaving a lot of "orphan" lines ("incorrect boundaries")
when a large map is overlaid with a much smaller map. This doesn't
affect calculation much, but it does affect display.
If I were only working with a few target areas, I could use v.digit to
correct the result, but with a large and complex map the job is rather
daunting!
v.distance - when using the -a option (measure distance to all areas in
boundary), it cannot create the database table for to_attr outputs.
example from Spearfish:
> v.distance from=bugsites from_type=point to=archsites to_type=point -a
> upload=dist,to_attr column=dist,character to_column=str1 table=test2
> 100%
> 100%
> DBMI-DBF driver error:
> Column 'dist' already exists (duplicate name)
> Cannot create table.
> Error in db_execute_immediate()
> ERROR: Unable to create table: 'create table test2 (from_cat integer, dist
> double precision, dist double precision )'
or, if I alter the column order:
> upload=to_attr,dist column=character,distance to_column=str1 table=test2
> 100%
> 100%
> SQL parser error: syntax error, unexpected ',', expecting NAME
> processing ','
> in statement:
> create table test2 (from_cat integer, , distance double precision )
> ERROR: Unable to create table: 'create table test2 (from_cat integer, ,
> distance double precision )'
Cheers,
Richard Chirgwin
