[GRASS-user] R-GDAL incompatible libraries
Kim Besson kimbesson1981 at gmail.com
Tue Mar 2 05:45:41 EST 2010
Hi
I have installed R from Ubuntu repositories. My grass installation is a
Weekly snapshot.
I had to install rgdal since it doesn't exist in UBUNTU repositories neither
CRAN and the same with spgrass6.
Ok I will rebuild grass and reply again to mailing list
Thanks
Kim
Did you install grass from source? Did you install R, spgrass6 from
> source?
> - If you have installed grass from source, then try to rebuild grass
> (after having installed R and the rest).
> - If you have grass from the ubuntu repositories, the you should
> probably stick with R and the rest from the repositories as well. If the
> latter is the case and it does not work, then there is a problem.
> Tell us a bit more...
> Nikos
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100302/a0192f15/attachment.html
