[GRASS-user] R-GDAL incompatible libraries
Kim Besson
kimbesson1981 at gmail.com
Tue Mar 2 07:05:15 EST 2010
Ok I have just installed latest GRASS snapshot and I got the following error
> precip30n <- readVECT6("precip_30ynormals", ignore.stderr=TRUE)
ERROR: Incompatible library version for module. You need to rebuild GRASS
or untangle multiple installations.
What I would like to know is the versions of R and spgrass6 that I should
install on my system in order to not get this errors?
Thanks
Kim
2010/3/2 Kim Besson <kimbesson1981 at gmail.com>
> Hi
> I have installed R from Ubuntu repositories. My grass installation is a
> Weekly snapshot.
> I had to install rgdal since it doesn't exist in UBUNTU repositories
> neither CRAN and the same with spgrass6.
> Ok I will rebuild grass and reply again to mailing list
> Thanks
> Kim
> Did you install grass from source? Did you install R, spgrass6 from
>> source?
>> - If you have installed grass from source, then try to rebuild grass
>> (after having installed R and the rest).
>> - If you have grass from the ubuntu repositories, the you should
>> probably stick with R and the rest from the repositories as well. If the
>> latter is the case and it does not work, then there is a problem.
>> Tell us a bit more...
>> Nikos
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100302/f33acd6a/attachment-0001.html
