[GRASS-user] R-GDAL incompatible libraries
Νίκος
Νίκος
Tue Mar 2 07:29:17 EST 2010
On Tue, 2010-03-02 at 12:05 +0000, Kim Besson wrote:
> Ok I have just installed latest GRASS snapshot
Latest snapshot of grass65 or grass70?
> and I got the following error
> > precip30n <- readVECT6("precip_30ynormals", ignore.stderr=TRUE)
> ERROR: Incompatible library version for module. You need to rebuild
> GRASS
> or untangle multiple installations.
> What I would like to know is the versions of R and spgrass6 that I
> should install on my system in order to not get this errors?
Check the last posts in this thread:
-http://lists.osgeo.org/pipermail/grass-stats/2009-January/000899.html
and afterwards,
and perhaps:
-http://n2.nabble.com/error-Incompatible-library-version-for-module-You-need-to-rebuild-GRASS-or-untangle-multiple-install-td3347115.html
Maybe there is (still?) a problem with grass70... ? Not sure (since I
haven't been messing around for a while).
Nikos
