[Fwd: [GRASS-user] r.cost vs. costallocation (arcgis)]
Paolo Cavallini cavallini at faunalia.it
Sun Mar 14 17:16:39 EDT 2010
>> From: António M. Rodrigues <amrodrigues at fcsh.unl.pt>
>> To: grass-user at lists.osgeo.org
>> Subject: [GRASS-user] r.cost vs. costallocation (arcgis)
>> Date: Sun, 14 Mar 2010 13:21:14 +0000
>> Cost distance and costallocation (arcinfo and arcgis) output two surfaces: an accessibility and an
>> allocation surface.
>> For verious reasons, I need both.
>> In GRASS, I had a look at r.cost, r.walk r.watershed and r.drain, trying to find a toll which could create
>> an allocation grid based on a cost surface. From what I could see, none of these tools will do.
>> I find it hard to believe that:
>> 	1. No one have had this problem before using GRASS,
>> 	2. there is no solution using GRASS.
>> If someone, anyone, could point me in "any" direction, it would be greatly appreciated. Even
>> something like: "dude, just give up, and go back to arcgis"...
>> If the solution involves programming a new tool, probably based on r.cost, is there some tutorials
>> online dealing with programming in GRASS?
Hi António.
Could you please explain us more clearly what do you (rather, ESRI) mean by
accessibility and allocation? I would be very surprised if this could not be done
with GRASS.
All the best.
Paolo Cavallini: http://www.faunalia.it/pc
