[GRASS-user] translucency and svg output
Vincent Bain
bain at toraval.fr
Thu Mar 25 13:56:30 EDT 2010
Ignoring the aim of Pete's graphical outputs, perhaps my advice will be
trivial, but quite often people want to keep vectorial formats very
"far" in the output process eventhough they don't have special
post-editing needs. I was of those till I understood raster formats
advantages for pre-press, among which:
* kind of stability between platforms/softwares (no surprise when
interpreting the format, as it often happens e.g. with poor quality
postscript interpreters);
* very acceptable accuracy (beyond 300 dpi for a color output is useless
regarding common printers technology);
* lightness (if you ever tried to generate a complex A3 pdf doc with
multiple translucent layers above a raster background, you might know
what I mean...)
It is quite easy with Grass to write a script that:
* outputs a ps file for each layer you need to overlay (may they be
numerous, you have control on image size and map extent),
* then performs the composition with a command line image editor (image
magick can interprete postscript if you have ghostscript installed on
your system) that does deal with blending options.
I can provide examples for those interested...
Vincent
Le jeudi 25 mars 2010 à 15:12 +0000, Glynn Clements a écrit :
> pete davidson wrote:
> > And then we discover that the 'svg' produced by cairo using the above script
> > is actually just a png in an svg wrapper.. At least for my particular
> > install of Grass. That's frustrating. Ahh well, back to the drawing board.
> Cairo falls back to rasterisation as soon as it encounters anything
> which it might not be able to implement using vector operations.
> For me, a simple "d.vect fields" produces "real" (vector) SVG output.
> You might want to experiment with the command options (and the
> environment variables used by the cairo driver) to see if a specific
> feature is triggering rasterisation.
