[GRASS-user] New module for fuzzy calsification added to svn
repository
Jarosław Jasiewicz
jarekj at amu.edu.pl
Mon Mar 29 09:06:12 EDT 2010
I forgot: If there is someone who can help me adjust this analysis to
analyze imagery data, please contact me. I know almost nothing on
analysis of such data but it seems it could be useful for it.
Jarosław Jasiewicz pisze:
> Hi list!
> I added new module r.fuzzy.system to svn repository:
> this is standalone classification module, to work require only sets
> and rules definition (see module description and small tutorial in
> description.html)
> what module do (internally):
> - parse sets and rules text files before calculation
> - creates fuzzy sets based on user's definition
> - implicate fuzzy rules form antecedents to consequent based on user
> rules
> - aggregate consequents
> - defuzzify final set
> additional features:
> - output fuzzy maps for particular rules
> - output consequents and aggregated fuzzy set for particular cells
> (without map calculation)
> In spite that module has the same name as that created by Francois
> Declaux, it is completely new tools without any references to that
> except it was created for that same reasons. Module r.fuzzy system do
> not require r.fuzzy and r.fuzzy.logic to work, but these modules can
> be used to trace intermediate results (they use the same fuzzy
> algorithms)
> It fact module do almost all what I assumed, but there are probably
> lot of bugs and errors. Because it was rather difficult coding
> (especially text file and expression parser) any help with testing
> will be appreciated. I will also appreciate if someone with better
> English than mine can help me write tutorial on fuzzy logic in GIS
> Known issues:
> If there are cells for which membership in all sets is 0 module
> returns null. It is probably difficult to solve without extensive
> graphical UI with additional correction and check-out tools so
> probably will remain unsolved.
> regards
> Jarek Jasiewicz
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
