[GRASS-user] GRASS 7.0 - OS X install problem
    Stuart Edwards
    sedwards2 at cinci.rr.com
    Sat May  8 15:38:55 EDT 2010
On May 8, 2010, at 11:19 AM, William Kyngesburye wrote:
> On May 8, 2010, at 10:03 AM, Stuart Edwards wrote:
>> On May 8, 2010, at 9:44 AM, William Kyngesburye wrote:
>>> SVN updated so the Mac app starts the new python init.
>>> I don't know about the TclTk NVIZ problem.  I have a different one - no rule to make target anim_support.o.
>> Now I get the following error:
>> SEsMacPro:~ stu$ '/Applications/GRASS-7.0.app/Contents/MacOS/grass.sh'; exit
>> Rebuilding Addon HTML manual pages index...
>> cp: /Applications/GRASS-7.0.app/Contents/MacOS/docs/html/grass_icon.png: No such file or directory
>> Rebuilding Addon menu...
>> Python 2.6.4 found.
>> arch: posix_spawnp: /opt/local/bin/pythonw2.6: Bad CPU type in executable
>> logout
>> [Process completed]
> That's because the startup forces Python to run in 32bit mode, because wxpython can't be built for 64bits yet (!).  And the python you have in /opt/local (macports?) is then probably 64bit-only.  GRASS is probably finding the macports python first because it's first in your shell PATH.
> Which python did you intend to use for GRASS?  If the macports python is 64bit only, they probably don't have wxpython at all.
 Hadn't really considered which version to use ......... but obviously should.   Since opt installs itself at the head of the PATH, it always finds that version first.   I saw some discussion by you about specifying a GRASS_PYTHON - does that work and if so can you please provide details.  Came across this which seems relevant to the 32 / 64 bit issue.
http://community.activestate.com/forum/using-32-bit-python-komodo-under-snow-leopard
The Python that comes with 10.6 apparently honors an environment variable called VERSIONER_PYTHON_PREFER_32_BIT. If that's set to 'yes', invoking Python from /usr/bin/python brings Python up in 32-bit mode. By default, it comes up in 64-bit mode.
Curious that I don't have any problem running the wxpython gui with GRASS 6.4
Stu
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100508/7eb12886/attachment.html
