[GRASS-user] Problem importing vector
Kurt Springs ferret_bard at mac.com
Tue May 18 20:21:54 EDT 2010
OKay,
That solved the problem
Thanks.
Kurt
On May 18, 2010, at 4:32 AM, Markus Metz wrote:
> Kurt Springs wrote:
>> I am having a problem importing a vector from a shape file.
>> I am am running:
>> v.in.ogr -o -e dsn=/Users/kurtsprings/grassdata/NED/03604870/03604870.shp output=steam_water min_area=0.0001 snap=-1 --overwrite
>> The message I get is:
>> Over-riding projection check
>> DBMI-SQLite driver error:
>> Unable to open database: unable to open database file
>> Unable to open database </Users/kurtsprings/grassdata/NH-UTM/PERMANENT/sqlite/> by driver <sqlite>
>> Unable open database </Users/kurtsprings/grassdata/NH-UTM/PERMANENT/sqlite/> by driver <sqlite>
> </Users/kurtsprings/grassdata/NH-UTM/PERMANENT/sqlite/> is a
> directory, not a file. For sqlite, the database must be a file, e.g.
> sqlite.db. For dbf, the database must be a directory, e.g. dbf/
> db.connect driver=sqlite database="$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db"
> should fix it, check with db.connect -p, the result should be
> driver:sqlite
> database:$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db
> Markus M
>> Layer: 03604870
>> I switched the database driver to sqlite after I created the location and mapset, before I started importing anything.  Any ideas as to what the problem might be?
>> Kurt
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
