[GRASS-user] Need some help in converting a contour map to DEM
map...
Achim Kisseler
ak7 at jupiter.uni-freiburg.de
Tue Nov 9 06:57:54 EST 2010
Hi Nikhil,
e.g. you can do it with:
v.surf.rst
(http://grass.osgeo.org/gdp/html_grass64/v.surf.rst.html)
Does this help?
Achim
Am 09.11.2010 12:28, schrieb nikmor:
> I am trying to import an contour file and trying to come up with an DEM map
> from it. I tried it my way but end up with wrong output. I am looking
> forward for some one who can import this map and convert it to DEM and
> finally and most importantly we should be able to view the output in NVIZ. I
> have attached the folder having the contour data, this data is of IIT
> bombay.
> If someone succeeds in doing this, please send me the procedure (with all
> the details of resolution, grid size etc). I will be very thankful to one
> who helps me out of this problem.
