[GRASS-user] Mac Pathon 64 Bit
wagner wagner at math.uni-landau.de
Fri Aug 12 12:56:58 EDT 2011
Thanks, this works fine now.
Am 12.08.2011 um 18:37 schrieb William Kyngesburye:
> wxPython could be considered the only GUI option - there is the TclTk GUI still in GRASS 6.4, but I don't think it's kept up to date now, and it is not in GRASS 7.
> Is there a reason for using your custom /opt/local Python for GRASS?  I don't think the older system Python 2.6 version is a problem for the GUI.
> If you are using the /opt/local Python unintentionally, probably what is happening is that it (or MacPorts) added something to your shell init (.bash_profile) to add /opt/local/bin to your PATH.  GRASS then picks this up and uses the Python it finds there.  You can get around this by adding a line to your .bash_profile:
> export GRASS_PYTHON=/usr/bin/python2.6
> On Aug 12, 2011, at 11:20 AM, wagner wrote:
>> Is this the only possibility to use a GUI an OS X?
>> Am 12.08.2011 um 18:05 schrieb William Kyngesburye:
>>> It won't work 64bit - wxPython 2.8 (included in the GRASS package) can't be built 64bit on OS X.
>>> On Aug 12, 2011, at 9:02 AM, wagner wrote:
>>>> Hello,
>>>> I tried to install GRASS with GUI on my Mac with Mac OS 10.6.6 (Snow Leopard) 64 Bit, but I always got the following message while starting:
>>>> arch: posix_spawnp: /opt/local/bin/pythonw2.6: Bad CPU type in executable
>>>> I loaded it from http://www.kyngchaos.com/software/grass and as well all the required packages.
>>>> I hope that anyone has a solution for that.
>>>> Kind regards,
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> "Time is an illusion - lunchtime doubly so."
> - Ford Prefect
Dr. Ralf Wagner
Fachbereich 7
Institut für Mathematik
Universität Koblenz-Landau, Campus Landau
Fortstraße 7
76829 Landau
Tel.:   +49/(0)6341 280-31-250
Fax:   +49/(0)6341 280-31-385
E-Mail: wagner at math.uni-landau.de
          wagnerr at uni-landau.de
Web: http://ifm.uni-landau.de
        http://mathematik.uni-landau.de/wagner
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110812/032e5a73/attachment-0001.html
