[GRASS-user] Python-Loop over points
Johannes Radinger
JRadinger at gmx.at
Wed Feb 2 06:39:34 EST 2011
Hello,
I am performing e.g. the r.stream.basins calcutlation in python:
grass.run_command("r.stream.basins",
dir = "flow_direction",
points = "point1",
basins = "output")
that's working perfectly in the case of one single point in "point1".
How can I do that multiple times when the point layer consist of e.g. 5
points and I want to create an output for each point (create 5 output rasters).
How can that be done in a python script?
thank you
Johannes
NEU: FreePhone - kostenlos mobil telefonieren und surfen!
Jetzt informieren: http://www.gmx.net/de/go/freephone
