[GRASS-user] Python-Loop over points
Daniel Victoria
daniel.victoria at gmail.com
Mon Feb 7 19:25:31 EST 2011
Hi Johannes,
You will need to use for loop. Something like this (UNTESTED!)
for p in range(5):
points_map = "point"+str(p)
out_map = "output"+str(p)
grass.run_command("r.streams.basins", dir = "flow_direction,
points=points_map, basins = out_map)
That should work, or at least something similar
Daniel
On Wed, Feb 2, 2011 at 9:39 AM, Johannes Radinger <JRadinger at gmx.at> wrote:
> Hello,
> I am performing e.g. the r.stream.basins calcutlation in python:
> grass.run_command("r.stream.basins",
> dir = "flow_direction",
> points = "point1",
> basins = "output")
> that's working perfectly in the case of one single point in "point1".
> How can I do that multiple times when the point layer consist of e.g. 5
> points and I want to create an output for each point (create 5 output rasters).
> How can that be done in a python script?
> thank you
> Johannes
> NEU: FreePhone - kostenlos mobil telefonieren und surfen!
> Jetzt informieren: http://www.gmx.net/de/go/freephone
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
