[GRASS-user] Re: "fe_sendauth: no password" even though password
supplied
Aren Cambre
aren at arencambre.com
Sun Feb 6 22:32:03 EST 2011
Well, this is weird. If I add *-t* ("Do not create attribute table" per
http://grass.osgeo.org/grass64/manuals/html64_user/v.in.ogr.html), it all
works.
I'm guessing this is a bug, so I've filed a report at
http://trac.osgeo.org/grass/ticket/1274.
Aren
On Sun, Feb 6, 2011 at 4:57 PM, Aren Cambre <aren at arencambre.com> wrote:
> I am flamboozled by this error. I am running GRASS GIS 6.4 on Windows 7 32
> bit.
> I am running this command (user ID and password redacted):
> *v.in.ogr -o "dsn=PG:dbname='de' host=localhost port=5432 user='XXX'
> password='YYY' sslmode=disable" layer=consistent.master output=master_grass4
> --verbose*
> Here's the result:
> *Over-riding projection check*
> *Layer: consistent.master*
> *Width for column school_zone set to 255 (was not specified by OGR), some
> strings may be truncated!*
> *Width for column vehicle_color set to 255 (was not specified by OGR),
> some strings may be truncated!*
> *Width for column offense_location set to 255 (was not specified by OGR),
> *Width for column work_zone set to 255 (was not specified by OGR), some
> *DBMI-Postgres driver error:*
> *Cannot connect to Postgres: fe_sendauth: no password*
> *supplied*
> *Unable to open database <host=localhost,dbname=de> by driver <pg>*
> *ERROR: Unable open database <host=localhost,dbname=de> by driver <pg>*
> I don't understand why I am getting the highlighted error. I am supplying
> the user ID and password for the DB's root *and only* user. I know these
> are correct; I've triple-checked. And it's able to read the database;
> otherwise it wouldn't be able to see those four columns and complain about
> the width.
> Am I missing something?
> Aren Cambre
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110206/31c31af6/attachment.html
