[GRASS-user] i.cluster not working in GRASS 7
daniel mcinerney
daniel.o.mcinerney at gmail.com
Fri Feb 18 03:24:11 EST 2011
Hi Ned,
I have been using i.cluster in GRASS 7 on a 64-bit fedora server,
without any trouble. However, I managed to replicate your problem
and create a single class output by setting the parameter
'sample=5,5' as you had done in your example. If I run i.cluster without
that parameter, the signature file and classification output both
have the number of predefined classes.
Can you see if this helps with your data?
Regards,
Daniel.
On Thu, Feb 17, 2011 at 7:49 PM, Ned Horning <horning at amnh.org> wrote:
> Hi - I would like to do an unsupervised classification using i.cluster from
> GRASS 7 on my Ubuntu 64-bit machine. When I run i.cluster then i.maxlik on a
> Landsat image I only get one output class, the entire image. Only one class
> appears in the signature file so the problem is with the i.cluster step. I
> tried running i.cluster on different images and always get just one class.
> Here is the command line I'm using:
> i.cluster group=TM_r15c33 at PERMANENT subgroup=AllBands
> signaturefile=IsoDataSigs2 classes=20 sample=5,5 convergence=99.9
> min_size=10000
> Is anyone able to get i.cluster to work properly? It would be helpful to
> know if it's a user problem or a bug.
> Thanks in advance to anyone who can help.
> All the best,
> Ned
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110218/1280f015/attachment.html
