[GRASS-user] d.his command in GRASS 6.4.1 with wxpython GUI?
    Martin Landa
    landa.martin at gmail.com
    Fri Jul 22 14:21:49 EDT 2011
2011/7/22  <Thomas.Adams at noaa.gov>:
> to create a very nice shaded relief map, draped with another raster, such as elevations. How do I do this with the wxpython GUI? Running the command at the terminal does not work because it requires d.mon to be run to select a monitor -- does this mean the d.his command can not be used with the wxpython GUI?
choose "Various raster map layers" from the toolbar in Layer Manager,
choose "Add HIS map layer". If you type the command in wxGUI command
prompt it should also work (at least in 6.4.2+).
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
