[GRASS-user] d.his command in GRASS 6.4.1 with wxpython GUI?
Thomas.Adams at noaa.gov
Fri Jul 22 15:14:38 EDT 2011
Martin,
Thank you; I'm still getting use to the new GUI and did not even look at that -- too obvious, I guess!
Cheers!
Tom
----- Original Message -----
Date: Friday, July 22, 2011 2:21 pm
Subject: Re: [GRASS-user] d.his command in GRASS 6.4.1 with wxpython GUI?
To: Thomas.Adams at noaa.gov
Cc: grass-user at lists.osgeo.org
> Hi,
> 2011/7/22 <Thomas.Adams at noaa.gov>:
> > to create a very nice shaded relief map, draped with another raster,
> such as elevations. How do I do this with the wxpython GUI? Running
> the command at the terminal does not work because it requires d.mon to
> be run to select a monitor -- does this mean the d.his command can not
> be used with the wxpython GUI?
> choose "Various raster map layers" from the toolbar in Layer Manager,
> choose "Add HIS map layer". If you type the command in wxGUI command
> prompt it should also work (at least in 6.4.2+).
> Martin
> Martin Landa <landa.martin gmail.com> *
