[GRASS-user] RE: Hardware config/limits
nunosousa84
nuno_sousa_1984 at hotmail.com
Sun Jun 5 06:21:37 EDT 2011
ok i was able to delete the cat_ column with: v.db.dropcol (I think this
deletes permenently? or just omits?). Now i have another problem the layer i
created wih r.random has a column with double precision type value, but
v.patch only allows the patch of two maps with same type (in my case would
be integer). Is it possible to change the column type from double precision
to integer?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Hardware-config-limits-tp6423485p6441839.html
Sent from the Grass - Users mailing list archive at Nabble.com.
