[GRASS-user] making fcell raster maps using climate data
Pierre Roudier
pierre.roudier at gmail.com
Sun May 29 20:40:46 EDT 2011
Hi Bulent,
My first idea - but I may be biased as I come from the R world - would
be to make the imports steps of your data from R. R has a XLS
reader(but I usually find it safer to first export your spreadsheet to
a CSV file).
Hope this helps,
Pierre
2011/5/30 Bulent Arikan <bulent.arikan at gmail.com>:
> Dear List,
> I have an Excel file that contains precipitation data in 13 columns (mean
> values for each month and annual average) from a region between certain
> years (in rows): eventually showing temporal changes in precipitation
> values. The data are taken at a weather station whose coordinates are known.
> I want to use this file in order to make an fcell raster map in GRASS. After
> some research I found few leads and mostly on interpolation of data.
> However, I am confused about the actual process turning the data in Excel
> into a raster map. I will greatly appreciate any suggestions as to which
> module to use and how to arrange the data.
> Thank you,
> BÜLENT
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Scientist
Landcare Research, New Zealand
