[GRASS-user] Re: European Datum 1950 is not saved in the region
information
Hamish
hamish_b at yahoo.com
Sun Nov 13 22:05:40 EST 2011
Hamish wrote:
> > do you use proj4 version 4.7.1svn? If so, please try
> > version 4.7.0
Sophia:
> Sorry, can you give me information on how to use version
> 4.7.0. I've downloaded the zip file from http://trac.osgeo.org
> /proj/ but I'm not sure what to do with the files. I assuem I
> must compile it.
actually you just have to replace the "epsg" file with an older
copy,
rename the file C:\Program Files\GRASS 6.4.SVN\proj\epsg
to something like "epsg.471dev"
then download the older 4.7.0 copy from here:
http://trac.osgeo.org/proj/export/2118/tags/4.7.0/proj/nad/epsg
and put it in the same place as "epsg" & hope for the best.
> I was able to set the datum using g.setproj, then g.proj -p
> shows the datum and towgs84 params correctly:
> -PROJ_INFO-------------------------------------------------
> name : Universal Transverse
> Mercator
> datum : eur50
> towgs84 : -87.000,-98.000,-121.000
> proj : utm
> ellps : international
> a : 6378388.0000000000
> es : 0.0067226700
> f : 297.0000000000
> zone : 30
> -PROJ_UNITS------------------------------------------------
> unit : meter
> units : meters
> meters : 1.0
Yes, g.setproj uses GRASS's internal datum tables to set things
up, so it isn't affected by the epsg file problems & works ok.
On the downside, g.setproj doesn't know about EPSG codes and
so can't expand from them.
> However, when I try the same for the Finland Uniform
> Coordinate System (created through the wizard selecting EPSG
> code 2393) g.setproj doesn't find the D_KKJ datum,
the location wizard doesn't use g.setproj, it is a work-alike.
the location wizard uses "g.proj -c" which relies on PROJ.4
for the datum and ellipsoid options, and that's the one which
is not happy right now.
for more details see http://trac.osgeo.org/proj/ticket/122
Hamish
