[GRASS-user] wxGUI Graphical Modeler - variables
Luís Ferreira
lferreira75.1 at gmail.com
Mon Sep 26 09:40:56 EDT 2011
Hello.
I have some selected lines in a command line script:
#! /bin/sh -x
MYMAPSET=`g.gisenv -s get=MAPSET`
targetdir=/home/lf/TEMP/
LIST=`g.mlist type=rast separator=, pattern="clip_toar*" mapset=
$MYMAPSET`
echo "$LIST"
i.group group=group input=$LIST
r.out.gdal -c -f input=group format=HFA type=Float32 nodata=0 output=
$targetdir/$MYMAPSET.clip_toar.img
g.remove group=group
In wxGUI Graphical Modeler, how can I use the variables inside the
commands options? I'm trying using string data type variables
declaring variables
MYMAPSET
default value `g.gisenv -s get=MAPSET`
targetdir
default value /home/lf/TEMP/
then using in r.out.gdal options
r.out.gdal -c -f input=group format=HFA type=Float32 nodata=0 output=%
targetdir/%MYMAPSET.clip_toar.img
or
Without results.
Anyone have ideas how to solve this problem? Is it possible in Graphical
Modeller?
Thank you.
Luís Ferreira
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110926/2125e3a6/attachment.html
