[GRASS-user] region settings
Daniel Lee lee at isi-solutions.org
Wed Aug 8 08:47:20 PDT 2012
Hi Janet,
Tthe data seems to be in a geographic (angular) coordinate system, which
means that you won't be able to get resolution in meters. Due to the
curvature of the Earth's surface, one arc second has a different length at
different latitudes. That's exactly what you're seeing in your example -
0:00:01 means 0° 0" 0'. The notation is in degrees minutes seconds (DMS)
rather than decimal degrees (DD), which I prefer, but however you look at
it, unless you reproject the data into a projected coordinate system like
UTM, etc., the resolution will be in that unit.
The short version of that long story is that your data sounds like it's
fine - 1 arc second is about 30m and so it looks like you've got the data
you wanted and GRASS interpreted it correctly.
Best,
Daniel
B.Sc. Daniel Lee
Geschäftsführung für Forschung und Entwicklung
ISIS - International Solar Information Solutions GbR
Vertreten durch: Daniel Lee, Nepomuk Reinhard und Nils Räder
Softwarecenter 3
35037 Marburg
Festnetz: +49 6421 379 6256
Mobil: +49 176 6127 7269
E-Mail: Lee at isi-solutions.org
Web: http://www.isi-solutions.org
2012/8/8 Janet Choate <jsc.eco at gmail.com>
> Hi all,
> this seems silly, but i am a bit confused as haven't had this be an issue
> before.  i downloaded data from USGS NED (they have changed the process
> since i last used). i requested data at 1 arc second (which is supposed to
> be approx 30 meters)
> i set up a new grass dataset, reading the projection and datum terms from
> a georeferenced data file (referring to the w001001.adf file).  at the 'set
> default region extent and resolution' page, the correct N/S/E/W coordinates
> are shown, however, the N-S & E-W resolution are set to 0.000277777777841.
>  it would not let me change the resolution.  accepted and set the region.
>  then used r.in.gdal to import the raster (the w001001.adf file), then set
> the region to the new dem raster and displayed it.  so all seemed to work
> fine.  however, when i check the region settings with g.region -p, the
> nsres/ewres are 0:00:01.
> i need this to be a 30 meter DEM, and am confused as to what the present
> resolution actually is, as i requested 30m (1 arc second) at download from
> NED.
> anyone have any tips regarding this?
> thank you,
> Janet
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120808/ff553eb0/attachment-0001.html>
