[GRASS-user] SQlite Error, Mac OS X
Johannes Radinger
JRadinger at gmx.at
Tue Feb 28 10:44:01 EST 2012
Hi again,
I just found out what causes the problem:
It seems that this is related with the length of the column (attribute) names. After cropping them to <8 it works. Anyway that is seems
to be a good reason to stick to short attribute names especially when
one wants to exchange data with e.g ArcView.
Just a suggestion: Maybe the Error message should be more specific for the user.
cheers,
/johannes
-------- Original-Nachricht --------
> Datum: Tue, 28 Feb 2012 12:01:08 +0100
> Von: "Johannes Radinger" <JRadinger at gmx.at>
> An: grass user list <grass-user at lists.osgeo.org>
> Betreff: [GRASS-user] SQlite Error, Mac OS X
> Hi,
> When I try to open the attribute table (sqlite db) of a line vector with
> around 100 columns and several 1000 lines I get an error message in GRASS6.5
> SVN (Mac OSX).
> After the error message pops up (saying only error, no specific
> description) the attribute table opens and shows the column heads but no entries and
> the window seems frozen.
> When I check the sqlite datadase with the sqlite manager in firefox, there
> is no problem. There is also no problem when I try to open the simpler
> vector atrribute tables (with less lines and attributes).
> I am not sure if that is a known problem or how can I tackle it. There is
> also a crash report from my OS created (Console report) which is attached.
> Cheers,
> Johannes
> NEU: FreePhone 3-fach-Flat mit kostenlosem Smartphone!
> Jetzt informieren: http://mobile.1und1.de/?ac=OM.PW.PW003K20328T7073a
Ihr GMX Postfach immer dabei: die kostenlose GMX Mail App für Android.
Komfortabel, sicher und schnell: www.gmx.de/android
