[GRASS-user] Possible Bug: -6.5svn Build #51017 [FIXED?]
Rich Shepard rshepard at appl-ecosys.com
Thu Mar 8 12:16:39 EST 2012
On Thu, 8 Mar 2012, Rich Shepard wrote:
>  I just tried v.proj using the wxgui, but was unsuccessful.
   Working from the command line I believe I found the error, and it's not a
v.proj bug.
   I used the GUI to create a new location specifying a shapefile .prj for
the projection information. For some reason, that did not create the
PROJ_INFO and PROJ_UNITS files in the PERMANENT mapset.
   So, I start over from the command line and that should fix the problem.
Rich
