[GRASS-user] installing Grass 7 on ubuntu 11.04
    Vishal Mehta
    vishalm1975 at gmail.com
    Wed Oct 31 10:09:37 PDT 2012
manish,
remember that you have to be in the folder in which you downloaded the
source code, before ./configure
-vishal
On Wed, Oct 31, 2012 at 9:59 AM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> Hi,
> On 31 October 2012 17:34, Manish Gautam <manish.gautam29 at gmail.com> wrote:
> > Another thing is how the command ./configure is to be used on Ubuntu
> 11.04.
> > the terminal says the ./configure command not found though the necessary
> > compiler is already been installed on the machine.
> Are you in the right directory (in the folder with source codes)? Is
> configure script executable (chmod u+x configure)? It is always good
> idea for me to confirm these things at first.
> Note that once you get ./configure working, you will need to set
> parameters for configure script (listed here
> http://grass.osgeo.org/wiki/Compile_and_Install_Ubuntu#GRASS_GIS).
> Vaclav
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Vishal K. Mehta, PhD
Scientist
Stockholm Environment Institute - US
133 D St Suite F
Davis CA 95616
www.sei-us.org
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121031/4bdb67d9/attachment.html>
