[GRASS-user] installing Grass 7 on ubuntu 11.04
Nikos Alexandris nik at nikosalexandris.net
Wed Oct 31 10:14:08 PDT 2012
[forgot to cc to the list]
Manish Gautam:
> I am finding it difficult to install Grass 7 on my pc. I use Ubuntu 11.04.
> I have tried to install it using the instructions given in the link
> http://grass.osgeo.org/wiki/Compile_and_Install_Ubuntu. However, I am able
> to download and install the dependencies.
Could you please post the exact command you instructed?  And, any positive or
negative output?
> Another thing is how the command ./configure is to be used on Ubuntu 11.04.
> the terminal says the ./configure command not found though the necessary
> compiler is already been installed on the machine.
Actually, the "configure" executable file/program is to be ran from within the
directory in which it is located, i.e.  the grass source code root directory.
>From within which directory do you try to execute ./configure?  And along with
which parameters?
> (Can I download the binary file from here
> http://grass.fbk.eu/grass70/binary/linux/snapshot/ and install from here ?
I haven't tried that yet. Maybe someone else can help with this.
> Though again I am unable to run the installation script given there or
> extracting the tar file)
Nikos
