[GRASS-user] r.sun use - automaticcaly stopped process ?
simogeo
simon.georget at gmail.com
Thu Apr 18 01:52:58 PDT 2013
Hi Hamish,
Thanks for your reply.
Indeed, my post was uncompleted - sorry for that. I'm running the script
under Ubuntu 12.04 - 64bits with Intel® Core™ i7 CPU M 640 @ 2.80GHz × 4 and
5.8GB RAM.
I guess the hardware is supposed (and able) to do the hard work I ask for.
A lack of memory should produce a segmentation fault, no? The current error
message is not really explicit.
I've tried changing the resolution to 0.5 but I still have the same issue
... I will still investigate. Any clue/idea would be appreciate.
View this message in context: http://osgeo-org.1560.x6.nabble.com/r-sun-use-automaticcaly-stopped-process-tp5047682p5047885.html
Sent from the Grass - Users mailing list archive at Nabble.com.
