[GRASS-user] v.transform issue
Bulent Arikan bulent.arikan at gmail.com
Wed Aug 14 23:35:23 PDT 2013
Dear List,
I digitized a vegetation map and now I want to transform a centroid using 'v.transform' only using (x,y) values. I am getting this "failure" message on the Command Console of the Layer Manager:
Command 'd.vect map=SSOOF_map_vtransform at Vegetation_30m'
failed
Details: Coor files of vector map
<SSOOF_map_vtransform at Vegetation_30m> is larger than it
should be (240 bytes excess)
I am working in a UTM location at 30m res. This is a tiny centroid and the module runs without error message. I tried to transform the vector with and without -s flag (use transformation parameters instead of points).
What is the problem?
Thank you!
BÜLENT
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130815/fa986d4d/attachment-0001.html>
