[GRASS-user] v.transform issue
Markus Neteler neteler at osgeo.org
Sat Aug 17 14:08:17 PDT 2013
On Thu, Aug 15, 2013 at 8:35 AM, Bulent Arikan <bulent.arikan at gmail.com> wrote:
> Dear List,
> I digitized a vegetation map and now I want to transform a centroid using
> 'v.transform' only using (x,y) values.
Hi Bülent,
which GRASS version are you using?
> I am getting this "failure" message
> on the Command Console of the Layer Manager:
> Command 'd.vect map=SSOOF_map_vtransform at Vegetation_30m'
> failed
> Details: Coor files of vector map
> <SSOOF_map_vtransform at Vegetation_30m> is larger than it
> should be (240 bytes excess)
> I am working in a UTM location at 30m res. This is a tiny centroid and the
> module runs without error message.
what does v.info report on the resulting vector map?
Markus
