[GRASS-user] problems running grass7 on Ubuntu 12.04
Chad Ferguson terrafergus at gmail.com
Wed Feb 27 07:47:07 PST 2013
Nikos,
I did as you suggested.  Uninstalled, added the ppa and reinstalled but
unfortunately I am receiving the same error--
 /usr/lib/grass70/etc/Init.sh: No such file or directory
It seems as though I am missing some sort of shell script, the Init.sh??  I
can see the directory.
Very frustrating.
On Tue, Feb 26, 2013 at 8:29 PM, Nikos Alexandris
<nik at nikosalexandris.net>wrote:
> Chad Ferguson wrote:
> > I am trying to run GRASS 7 on Ubuntu 12.04.  I am new to both GRASS and
> > Ubuntu.  I believe I have it installed, but can't get version 7 to run.
> Hi Chad!
> How did you proceed in getting the software installed?
> If I am not wrong, the current version in the official Ubuntu repositories
> should (still) be 6.4.2-2build1 -- this is what you should normally see in
> Ubuntu's Software Center.
> If you see 6.4.3 and version 7 as well, does this mean that you added the
> some
> Ubuntu-GIS repository?
> Following links are recommended:
> * <https://wiki.ubuntu.com/UbuntuGIS>
> * <https://launchpad.net/~ubuntugis/+archive/ppa/>
> > When I search my Ubuntu Software Center it shows grass70 as installed.
> O-kay.
> > In a terminal when I type 'grass' I am prompted to run v. 6.4.3.  When I
> > type grass70 I receive the following message.
> > /usr/bin/grass70: 25: exec: /usr/lib/grass70/etc/Init.sh: not found
> Confused... :-/
> > I need to run GRASS 7 as I am trying to investigate the functionality of
> an
> > add-on that is specific to this version.
> > Certainly I have missed something along the way.  Can anyone help get me
> on
> > track?
> Try this from the scratch (if you want):
> 1. remove any installed grass package, e.g. by executing in a terminal
> sudo dpkg -r grass
> OR, simply search & remove it within from the Software Center!
> 2. Add the "ubuntugis-testing" repository available in Launchpad:
> <https://launchpad.net/~ubuntugis/+archive/ubuntugis-testing>.  The
> easiest
> way is to launch a Terminal, and execute the following:
> sudo add-apt-repository ppa:ubuntugis/ubuntugis-testing && sudo apt-get
> update
> 3. Install grass7 from either the Terminal by instructing;
> sudo apt-get install grass70
> OR via the Software Center (it should appear!)
> 4. Launch grass70 via the terminal OR via Ubuntu's menu (should be also
> easy
> to trace once installed!)
> Gd Luck, Nikos
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130227/ae8ea48f/attachment.html>
