[GRASS-user] dbase driver in grass7
Levente Juhász
jlevente89 at gmail.com
Wed Jul 3 23:07:54 PDT 2013
Thanks for the replies.
db.connect would do what I want, but I think my issue is a bit more tricky.
Actually, I use GRASS7 as a backend for some WPS processes, and as it seems
to me: every WPS process creates a temporary workspace. I may be able to
run v.db.connect via WPS, but it would have effect on a vector map (which
is also temporary), so it has nothing to do with the next process I want to
execute.
The reason I wish to use dbf driver instead of SQLite is the following:
There's a package called Geo-MHYDAS, which had a module m.definput [1].
This module gives the error message: ERROR: Sorry, but only dbf driver
accepted.
So that is why I want to find an "universal" solution.
Any thoughts?
Cheers,
Levente
[1]:
http://www.openfluid-project.org/resources/docs/mhydas/en/segmentation/html/m.definput.html
2013/7/3 Hamish <hamish_b at yahoo.com>
> MarkusM:
> > Note that the dbf/ subdirectory in the mapset must exist or must be
> > created by the user.
> I think that usually it gets created as needed automatically. There
> may still be a few places it doesn't, if so file a ticket to fix..
> (did a long audit for that in grass6 some time ago, tested in grass7
> last week & it was automatically created as needed.)
> Hamish
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130704/0794ab4c/attachment.html>
