[GRASS-user] dxf export with attributes (RESOLVED)
Linda Edwards lindaedwards at cinci.rr.com
Tue Jun 11 10:05:10 PDT 2013
After consulting several message boards the following steps were followed to provide a dxf-labeled vector point file initially created in GRASS.   This involved the use of a free dxf converter available at:
http://freegeographytools.com/2007/converting-shapefiles-and-arcinfo-coverages-to-autocad-dxf-format
Note that this is a Windows .exe program
1.  export the vector file as an ESRI-shape file using v.out.ogr.  (Initially I had an issue with the column name being too long _over 8 characters_when corrected all worked well).
2.  upload the data file to the dxfauthor converter using the File pull-down menu
3.  the shapes will be displayed in the main window
3.  select Convert to DXF and a series of several screens will allow you to select various options along with designating the location of the output dxf
4.  select Finish
At this point you should have a labeled dxf.
On Jun 11, 2013, at 9:01 AM, Linda Edwards wrote:
> I am trying to export a vector point file that has a single label for each point.  In the attribute table the labels are shown as being on layer 1.  However when I export the file using v.out.dxf the labels are all -1.  Is there another step to take before exporting the file such that it includes the label.
> Thanks for any assistance.
> Linda Edwards
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
