[GRASS-user] r.surf.nnbathy with GRASS 7?
Ivan Marchesini
ivan.marchesini at gmail.com
Mon Jun 17 23:43:27 PDT 2013
I use it in Grass 7. it works.
inviato da smartphone
Il giorno 18/giu/2013 02:38, "Hamish" <hamish_b at yahoo.com> ha scritto:
> Adam wrote:
> > Is r.surf.nnbathy compatible with GRASS 7.0? It doesn't seem to
> > be listed on the GRASS7 Raster AddOns page. And, the install
> > instructions that I have found all refer to GRASS 6.
> > I have the nnbathy binary from 6 working fine. Can I just copy over
> > the script and binary? Is there a new version?
> I don't think there is a newer version, but there's
> a good chance that the GRASS 6 one still works. Give
> it a try and let us know!
> In general cloned code is to be avoided, and svn
> supports symlinking, so a possible solution for
> known working addons (scripts) is to symlink in
> the parent directory. Hopefully the build system
> is not too grumpy about mixed python and shell
> scripts. If it is we should come up with a solution
> to fix that.
> regards,
> Hamish
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130618/34779b4d/attachment.html>
